Cam Pan Issue - Want it to look at one spot only
Hello, my apologies up front if this question has been asked (I tried to find anything similar but was unable to), but is there a way to set the cam pan to only look at one spot? I have one cam pan sitting on a window ledge looking at our backdoor and another cam pan sitting on a window ledge looking out towards the front of the house and street. The backdoor unit is great, only moves when motion is detected (which isn’t too often) but the one in the front of the house constantly moves around and much of the time faces the window blinds (which I don’t need to see what the other side of my blinds look like). I’d like to set the cam pan to look at our driveway and street and not move at all. Is this possible? Thank you in advance for any help you can provide.
Turn off motion tracking in the settings. That should prevent the camera from moving.
Also check to see if a Detection Zone is set.
If not, turn it on, set it to the entire area or smaller if that’s what you want, and point the camera where you want it.
It may move but should return to that position after 15 seconds.
