Cam only keeps 12 hours of detections
When looking at past events my camera only shows 12 hours of each day. Right now it’s only showing pm events but none of the am events. For example, yesterday morning I was able to see all events of the morning. But today I can only see yesterday’s pm events. The morning is missing from all past events.
Are you looking at events when you open the camera to live view or are you using the events page?
Open the camera to live view and go to the bottom of the page, do you see this?
Are you talking about SD card or cloud? Most likely you need to look on the “events” tab, and when you reach the end of what is shown, you need to “drag and hold” to get it to show more. You can also use the date/time filters.
If you go into the live view on the cam itself it will only show you the most recent stuff.
I am looking at All Events, I am looking by the dates, I am looking at every option there is to see past events, and I have a subscription that should allow me to see all events. But, for example tonight, I want to see the events that took place in the last 24 hours but it is only showing the pm events. I’ve gone back a few days also but it only shows for a 12 hour period of each day. This is beyond frustrating and quite frankly useless to me.
Are you saying the events are there but you can only view 12 hours at a time? Have you tried the “swipe up and hold” when you hit the end of the list to load more?
If something is behaving differently in the app than it did before, try clearing the cache within the app settings, and also withing your OS settings for the wyze app. You could also try totally uninstalling and reinstalling it.
Have you tried resetting the Filter (Funnel icon) ?
“I want to see the events that took place in the last 24 hours but it is only showing the pm events.”
“Are you saying the events are there but you can only view 12 hours at a time?”
:melting_face:
Yes, that’s the clarification I’m asking for…
If you take your finger and push/scroll up on the events page screen are you saying it doesn’t go all the way from say 11:00 PM to 00:01 AM ?
How do you get from a well described issue, with sufficient context and a clear example to a question with an opposite premise, that asks about something that makes little sense?
It is not at all clear what the issue is, that’s what we’re trying to determine. It could just be an issue of navigation in the app, or it could be an issue of actual periods of events not existing. The title implies one, the posts imply another.
What contribution have you made to trying to figure this out? So far, you’re just trolling.
The issue is so simple. Op is not seeing events over a 12 hour period in a given day. The title is consistent with the question. The example of being able to see tonights events but not the events earlier in the day already contradicts “are you saying the events are there”. No they’re not there. They are literally stating, I can only see the pm events, which is plural, meaning we’re not talking about viewing something for 12 hours because you can’t have two 12 hour pm events in a single day. You have 12 hour periods missing not just today, but on other days, so you can rule out navigation related issues. It just sounds like you’re not considering that the problem exists the way it’s described and that there’s a need to clarify what is actually happening according to your own experience.
Well since you claim to understand OP’s issue, what is your suggestion for a fix?
Navigation related issue definitely cannot be ruled out, since that sounds like exactly what is going on here. How about let OP provide the info/clarification instead of adding more confusion for no reason?
I have clarified it for you, as you asked. I would have offered a solution if I had one. My best guess is either an automation that might stop motion recording or cuts camera power on a set schedule or a network related issue where the camera is losing signal. I doubt it’s either of those because they’re not consistent with seeing yesterday’s morning events that are no longer there today. Almost sounds like a software bug, who knows. I would try a factory reset if I was experiencing this.
Maybe there’s something worth reading in this thread. It’s not an identical issue, but similar enough to read through.
Curious what your suggestion is now that there is no confusion about what’s happening.
You’re not the OP, why are you speaking for them?
While it may be that way in your mind, I won’t have any further suggestions until there is actual clarification/confirmation from OP. It is absolutely not clear if those events are gone or simply not showing, since they stated that they could go back to previous days and see 12 hours of events on those days, which implies they are NOT gone, and it is just a navigation issue.
There is no automation which deletes events.
I never suggested an automation deleted events.
I don’t have to be the OP to understand the question for you. If you’re still confused, you won’t be of any help anyway. This was never about you being unclear about the question. You just want to answer a question that no one asked.
