If I purchase a couple of pre-owned cameras, will I be able to connect them to my current subscription?
There is no reason you should not be able to add them to your subscription as long as the cameras work and are not a model that is attached to a previous account.
Jason, has this v3 behavior changed where someone could take a v3 and add it their account? If it has changed, can you give a summary on how moving a camera to a different account now works? Thanks.
That’s exactly how it works. Add the cameras to your account as a new setup and you’re done. The only exception is (I think) all or some of the wireless (battery) cameras that use a base station must be released by the prior account holder. I refuse to buy any of the battery cameras so I can’t give details.
