Buffering only on brand new cams
Just purchased a pan cam v4, v4.50.4.9222, and a standard v4 wired cam, v4.52.9.3415. Both buffer every 5 seconds. My older v3 and v4 cams work fine. The network signal is strong on all of them. Would it do any good to roll the firmware back on them? Thanks.
Your standard V4 has May 2025 firmware on it. The current firmware is 4.52.9.6119 from March 2026.
The 4.50.4.9222 firmware is for a Pan Cam V3 and is from April 2024. I suggest you make sure you have the current app. 3.13 before you try to update any of the firmware to the current versions.
Current information is here.
https://support.wyze.com/hc/en-us/articles/360024852172-Release-Notes-Firmware
