My light bulb Cam won’t connect to WiFi. It blinks blue continuously and will not connect. I have disconnected multiple times, power cycled, rebooted and restarted. No avail…. Any thoughts?
Welcome to the Forum, @bsortf! ![]()
Is this during initial setup, or have you been able to add Bulb Cam to the app already? If this is an initial setup issue, then what can you describe (or show with a photo, which might be even better) about where you have Bulb Cam installed? If you’re trying to set it up outdoors, then what happens if you temporarily move it inside (presumably closer to your Wi-Fi source) and try to connect it then?
