Battery cam pro audio
All the audio from the SD card for the battery cam pro is with echo. How can I fix it. My other cameras Wyze cam Pam v3 and the OG are with the same SD card and their audio are good.
I am having the same issue. It sounds like you’re in a well or a tunnel. Both my cams do this, but I’m on android.
