When will you get base station back in stock?
Welcome to the forum.
I would say probably never back in stock. If your existing base is broken or has stopped working and your cameras are off line you wouldn’t be able to connect your cams to a new base. To change to a different base the WCO cams need to be on line so you can delete them with the app, then delete the base from the app.
I recently switched bases because my original was having connection issues after 4 years. I deleted the cams while they were on line, deleted the base. Set up a spare base and paired the cameras to the base, back in operation.
03/12/2025 - Now listed in-stock in the Shop on the Wyze app @ $9.99.
At that price I’d guess it is the final clear out.
You’re probably right. Cables not included.
What I see on the product page on the Web site says, “30-day hassle-free returns.” When they seemed to be clearing out the Watches, that product’s page said that it wasn’t eligible for returns.
Your speculation is as good as mine.
Well regardless those with WCOs that want to keep them for a while may be smart to order one as a backup. Of course, if your base station fully dies, I don’t believe there is any way to transfer the cams over, so you have to catch it when it starts to flake out. Maybe just proactively replace it now…
Not a bad idea, especially at that price and with the knowledge that they’ve been listed out of stock before. I don’t have any experience with any of the Cam Outdoor models, but I understand trying to continue using something that seems to be working otherwise.
