Band is showing "1763" on the display
My wyze band all of a sudden is displaying an icon of the band with the number “1763” on it. I can’t sync. The display is responsive, I can reboot and power off, but it won’t do anything else but show this number. I’m assuming its an error code? Any help would be appreciated.
It sounds like it is on pairing mode. I got that too went I hit “reset” instead of “reboot” by mistake.
I think the only thing you can do now, is delete the band in the app and add it back. You will only lose and data that had not yet been transferred from the band. All of your history is saved on your Wyze account.
That’s exactly what it was. Thank you.
