Please change the behavior of the Forum back button so that you aren’t taken all the way out to Help & Feedback. The back button should just take the operator one level back. If I’m in a forum thread, take me back to the forum. If I’m in a forum take be back to the list of forums. Etc.
This is probably best accomplished by Wyze by popping you out to your default web browser rather than presenting the forum within the app. In the mean time, a workaround is to bookmark forums.wyzecam.com in your mobile web browser which will let it behave as you describe.
Yeah, we definitely don’t have the smoothest integration there yet. Sorry about that!
@Loki
Good suggestion for them depending on how much effort there is to update the app behavior. And good suggestion, I’ll probably use my browser on Wyze forums from now on. Just not as convenient when I’m already in the app. Thanks.
@UserCustomerGwen
No worries. I’d have thought this would already be a wishlist item or in progress but didn’t see it so figured I’d make it official. Maybe in a future update.
This is very frustrating! It’s one of my reasons I do not come here that often.
Another irritation is that the keyboard (on android) covers the posting area so I can not see what I am writing without closing the keyboard!
I’ve been posting here a lot and use Firefox on Android phone (okay, technically it’s Fennec) nearly exclusively. I haven’t had a single problem. Keyboard is fine, back button works as expected. If anything I prefer it to the desktop experience.
I’ve seen similar behavior on the iOS app when making posts. Most notable is not being able to get back up to see + modify the forum subject.
I have been frustrated with not having a back button in the forum on my iPad as well. The usual back button tosses me out of the app and I have to start all over again.
p.s. Having the banner cover selectable items is annoying as well @ phakemail.
@Mods, should this topic’s tags be updated? When I try to open the Forum from within the Wyze app ( Account ➜ Wyze Community ➜ Forums), the “Forums” line has a “” icon and launches my mobile device’s default Web browser (to forums.wyzecam.com which then redirects to the present domain) when I tap it. This is the case with both the current app and the v2.50x app, at least on Android, so it seems like this is no longer an issue.
Will check on it for you.
Thanks. While reading through this, I got the impression that the app was previously opening the Forum within Android WebView or its iOS equivalent (if there is one; I’m not a developer), but this doesn’t appear to be the case currently with Android. I don’t have iOS devices to test.
