Is it possible to turn off the automatic uploading of video to AWS? i.e. only store video on the SD card.
Yes, in each camera’s settings section (tap the gear icon from the live stream page) tap Alert Settings at the top, then and make sure the switches for Motion Detection, Sound Detection, Smoke Alarm Sound Detection and CO Alarm Sound Detection are all OFF. Then no clips will be uploaded to the cloud. These settings are separate from and independent of the settings for recording to the mSD card found in the Advanced Settings section.
Thanks for the reply. If the various detection switches are set to off, then the camera would not send any alerts - right?
