I want to temporarily disable my cameras when I am home as they constantly go off when they hear any sounds. There is an away button but when I touch it nothing happens and it stays yellow
you would want to utilize the shortcuts option. I have a shortcut that when I’m home I turn off notifications for all my “indoor” cams. my definition is all the cams that are facing rooms where my “outdoor” cams are looking through windows to the outside.
as long as II remember to press it, it works great.
here is some reading for the shortcuts you can use.
https://support.wyzecam.com/hc/en-us/articles/360022543292-Wyze-Cam-User-s-Guide
You beat me to it ![]()
As a note - you can also trigger shortcuts with timers or Wyze cam/sensor events. A cool feature update would be for geofencing events… or to be able to use ifttt triggers to trigger the shortcuts.
For geofencing, you may want to hop over and vote for this: Multiple User Geofencing Geolocation (incl. Home Monitoring). Be sure to click the VOTE button at the top.
