Automation, location triger, enter does not work
I built two location trigger automation, exit works fine however the arrival doesn’t work. I checked application permissions and location . Tried several times deleted the automation but it still doesn’t work. Any suggestions?
Since exit fires but arrival doesn’t, the permissions are probably fine and it’s more likely Android putting the Wyze app to sleep before you get home. I’d set the Wyze app’s battery usage to Unrestricted (Settings > Apps > Wyze > Battery) and check that Wi-Fi scanning is turned on under Location services, since Android uses it to notice you’ve arrived. After that, recreate the arrival automation once more and test it.
