Auto-disable camera motion detection when owner is home?
Hi all,
I was wondering if it’s possible to have motion detection and all notifications and recordings automatically disabled (without user intervention) when the owner is home and auto-activated when the owner leaves the premises? I’m guessing it would check if the app is connected to the same wifi network as the cameras/devices. If it’s not possible, maybe Wyze can develop a keychain type of device that would do this exact task.
Edit: I’m aware that Wyze works with IFTTT but I’ve never used it before. Would it do what I’m looking for above?
Thanks,
Jimmy
If you get the app IFTTT and connect it to Wyze.
Great. I’ll look into it. Thank you Mark.
Welcome to the community, @nyrangers. If you familiarize yourself with the search function, I think you would find all kinds of information on IFTTT (and other things) on this forum. :slight_smile:
For example:
https://forums.wyze.com/search?q=%23ask-the-community%20ifttt%20
