Apple Watch - how to turn off Wyze notifications during sleep
I have a new apple 7 watch. I have the sleep mode turned on but I still get people/movement notifcations with “Ding” and image all night long. Does anyone know how to turn them off during sleep? no other notifcations come through, just Wyze. My previous Garmin watch stopped all notifcations during sleep.
I think there is a setting on the watch to limit notification times. You can also set a Rule in Wyze to turn off Notification during a certain schedule.
is that what you are asking?
Use theatre mode in your watch during bed time
I like that. I don’t have an Apple watch, so excuse my ignorance. But what does Theatre mode give you?
sort of, sleep is suppose to turn off notifications automatcally at your “sleep time” and turn them on again at your 'wake time" without any user intervention. this does appear to be working for everything except Wyze. I dont mind if the phone gets notifcations since I leave that a floor below me on the charger overnight. With my Garmin watch this worked fine for everything including Wyze, but on the Apple Wyze is sneaking through and since it worked ok on the Garmin, I thought there may be an apple setting to change ( VS setting a rule)
I was hoping for a setting that gets applied by itself daily, I think theater mode has to be done manually?
Thanks for the Clarity. Wife has an Apple Watch, will test and see with that one
You can set a Rule to turn notifications off for your devices at a certain time and back on at another. Then the Watch should not notify you. However, Events will still be recorded.
Not sure if you found a solution for this, however if you go to your “focus” settings, and select the sleep setting, you can adjust what notifications can come through and what can’t. Also same with people. I use the Do Not Disturb at night and the only notifications I have setup is my family (in case of emergency) and the only app the notifies me is actually my Wyze front door camera… hope this helps…
