Anyone miss the V1 & V2 power pass through feature?
Just upgraded to the V3 but didn’t realize they no longer support the daisy chain feature. Found this on amazon and works great!
https://www.amazon.com/gp/product/B07FY9Z9GD/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
Absolutely, I didn’t know that it would not be on the V3. I had planned to piggy back my two V3’s to look both ways down my street.
Did you switch to a bigger power supply? If not, the stock power adapter has no problem powering 2 cameras?
No. Same power supply
Thanks good to know. I plan on doing the same if I can ever get some more v3’s
if you plan on using them outside make sure to find a way to seal these connections. that is the main reason the daisy chain ability was left out I believe. also be aware that once released if you plan on using the spotlight it will need a connection too, and currently it is set up to plug into the camera using something like this, im not sure how that will affect the cams themselves.
