Anyone else lost Person Detected Event Recording?
Under Event recording, Record event option for when a Person is detected is missing!
Worthless if the cameras won’t record on person detection, and yes, under account, Person detection is turned on. I even turned it off and back on, but under event recording its not an option anymore!!
I am getting no person detections for the last 2 days! Which means my porch lights dont come on either!
Under event recording you turn motion detection on, Person detection depends on the motion detection, then go into notification and turn on notify for person detection and it should work.
Weird, ok thanks. I used to have a little box to enable it that was with Motion, It said Person, Mortion, or Sound
