Anyone else have this problem with events?
I have six V2 cams active right now. One just stops sending up events. They all have sd cards and I still get the recordings just fine on the sd, and live view is just fine also. It just stops recording the 12sec events. If I restart the camera through the app, it will work for a few days, and then stop with no warning even though live and sd recording is fine. Any ideas?
edit: It’s the only one with the bridge.
Set up nightly (or daily) camera restarts via the rules. I did this and have havent had any issues since.
Great idea, thanks . . .
That’s odd. You shouldn’t have to do this work around. Did you check with technical support? I have a V2 with the bridge and I don’t have an issue with getting event notifications.
