i see most people that have modified the antennas for greater range have done so to the sensor and not the bridge. i’d like to lengthen the bridge antenna. has anyone done that yet?
Not sure about mod for the bridge …but I’ve used a USB extension cable to move the bride closer to the sensors that need the improved signal strength.
now THAT’S a good idea!
I can second this. Using a 3 ft USB extender cable between the camera and the bridge makes a massive difference in the range. I think not having the sensor up against the camera makes a difference.
I needed to move the bridge but not the cam that is mounted on a concrete wall …extended the bridge to the window closest by and the signal improved instantly…from 1 to 3 bars !
