Is there a way to turn on an audio notification on the Android app when either sound or motion is detected?
You can turn on notifications for motion detection and sound detection separately. In other words, you can have only sound, only motion, or both send notifications.
If you’d like to turn on or off the notifications go to the Wyze app, then the camera, then “settings” (
), then “notifications”. You can then turn on and off notifications here. The settings must be adjusted for each camera individually.
Thank you!
Dan
