To clarify, I’m trying to view the Wyze Cams on my Fire TV Cube (on TV) and need to connect Wyze Cams to Alexa in app in order for me to be able to do that. I have enabled the Wyze skill in the Alexa App and connected my Wyze Cam account and the last step is having the Alexa app discover my cameras. Even though my Echo Dot and phone running Alexa App are on the same wireless network, it is not discovering the Wyze Cams.
@Greg, thanks for all your help. I figured it out.
I have two accounts with Wyze Cam. One that I’m using to create/reply to these posts and shop on the website, and the other is the one I have my Wyze Cams registered to. Once I enabled the Wyze skill in the Alexa app using the correct account, Alexa was able to identify my cameras and I can now see them on TV using my Fire TV cube or Fire TV stick.
If you are having trouble with Alexa discovering your camera, try disabling the skill, then go into Alexa to enable the skill and sign into your wyze account from there . If you start in Wyze app first and enable the skill from there, then try to discover the camera, it may not work.
So just so I understand cause I’m having the same problem with getting my firestick with alexa enabled wyze skill on tv to recognize camera. Not only do the cam and firestick have to be on the same frequency buy they have to be synced to the same email. [Mod edit] I don’t know why the email address needs to have anything to do with it. I set my firestick up under my wife’s email and the wyze cam app under mine so now I gotta change one of them to match the other. That really kinda sucks. Thanks for the info if I got this right. If I’m wrong please let me know.
No, no your email doesn’t need to be the same, some have more then one Wyze accounts and Amazon accounts and mix them up …
Did you try login out(disable) and in(enable) of the Wyze skill in the Alexa app?
If it still not working, try logout and in of the Alexa app too …see if that helps you.
