I have four cameras. 2 Wyze Battery Cam Pro, 1 Wyze Cam v4 - 1 Wyze Cam v3. I have AT&T fiber 2 GIG Speed. A Modem Router DOCSIS 3.1. All of my camera’s are really close to the router. But whenever I launch the app to look at the live video, it will buffer and take so long to connect. The app wasn’t running in the background, so I have to force quit the the app, then restart it. and it still takes time getting a connection. All the cameras have the latest firmware version, I have an iPhone 17 pro Max, running the latest up-to-date iOS. I work at Apple, as a Genius and have troubleshooted by running speedtest right by each camera, and it’s off the chart.
Wyze please update the firmware and software so I can get the connection immediately. I actually bought a eufy Indoor Cam E30 4K to test it. That connection with that camera is immediate. I have many other old Wyze cameras that I don’t use because I wanted to get the latest version. I have supported the company from the very beginning when it was growing. I still support the company, but now I’m getting super frustrated, because I sometimes have to immediately see what’s going on outside, and I’m unable to.
Does anyone else have the same issue?
I can view events no problem, but whenever I want to see something live, like a door bell rang, or there was an event, It gets stuck on Step 2: Authenticating forever. I go in and out of the app, or back up and back into the camera, and it can take 20-30 seconds or never connect. I have 6 cameras, and it’s the same across the board. I swear it used to be faster. Maybe there is a authenticating server issue? Cameras all have great connection to our wireless network, and are close to the routers. Please at least look into what’s causing this issue. Once it’s connected, things are fine, no delays.
For the battery cam pro, you can turn power saving mode off and live view will load in approx 7 seconds, at least mine do. But unless you have them wired or connected to solar panels, battery charge suffers significantly. I have 4 on solar panels with power saving off for best live view loading results. Batteries always 98-100% in moderate traffic areas.
My connectivity issues started around 2 months ago. I have several types of wyze cameras and the behavior is the same for the old er and newer ones.
Can you provide some information about your system.
- Cellphone brand/model and is the OS current
- Is the Wyze app updated with latest firmware
- All cams updated with latest firmware
- Router specs
- How frequently do you reboot, clear cache for applicable devices/equipment
- Any additional info that might be useful
Since it shows up on both old and new cams, the phone or your home Wi-Fi is the likely common factor. A quick split test: with Wi-Fi turned off on the phone, open live view on one camera and note how long it takes, then do the same on Wi-Fi. If cellular connects fast and Wi-Fi stalls, that points to your home network rather than the cameras, so the router (band steering, a mesh node, or a crowded 2.4 GHz band) is the next place to look.
