My dogs roam the backyard while I’m at work and they’ve been known to get out. Is there some way for Wyze sensors, cameras (preferred), or non-wyze solution to sense an AirTag that way the airtags I have attached to my dogs’ collar regularly check in? I don’t have Wyze sensors outdoors, but would consider adding some if this is a feature, In case it helps, I have two Outdoor Wyze cams and a Wyze Flood with a v3 attached.
Welcome to the Wyze User Community Forum @seancolinfort!
There isn’t any way for Wyze devices to integrate with the Apple AirTag to sense it’s signal. Each is a proprietary technology. The Cams don’t have sensors in them for that and the Wyze Sense Sensors are RF sensors that only communicate with the Wyze Sense Hub.
As I understand it, AirTags are close range Bluetooth devices that update their location signal thru other nearby Apple devices and NFC enabled Android devices. Wyze devices don’t have this capability.
