Trying to setup additional chime for doorbell. The instructions indicate go to “extended devices”. There is no option for that in the app. How do I set up the additional chime? Using android. Thank you.
Under each camera there used to be an “Extended Devices” which is where you’d find the Wyze Sense Hub, etc. Looks like it’s called “Accessories” now. I think if you go to your Doorbell → Settings (gear) → Accessories. You should see your existing Wyze Chime, and you tape the “+” at the top right to add another. Give that a shot.
