strong textI’m trying to install home monitoring system, It’s asking me to add a device, yet it is not giving me any choices to choose from. I cannot move on from this point. help.
Have you activated any of the sensors? Do you have other Wyze devices such as cameras or the V1 sensors? You should see those items available to add to HMS.
I have 3 cameras, none of them are showing up on the add device page.
To the Hub, you can add the keypad and the sensors (entry/contact and motion) only.
Under Monitoring is where you can add up to 5 security cameras but they are not part of the “monitoring” that will trigger the alarm (also note that only the v2 entry and motion sensors work with triggering the alarm system).
