I have added a new Wyze camera.
I have Cam Plus unlimited, but there is no option to adda new camera/
The only options are Free trial or Cam plus single subscription?
Can you help?
When you scroll to the bottom of Cam Plus, do you see a link that says “Add Cameras”?
Can you post screen shots of what you see.
Yes I have found it thank you!
I have 2 cameras on the yearly Cam Plus plan.
How do I move them to the Annual Plan Unlimited?
Henry.
Henry
Go to the Yearly Plan and remove it from there first. Then they should appear as being available to the Unlimited Plan
Make sure you have the latest Wyze app version installed, currently 2.37.2 (1) for iOS/iPadOS.
In Services > Cam Plus > Annual Plan yearly, tap the cam you wish to move, select “Unassigned”.
Under “Unlimited”, scroll down to “Add Cameras”, tap the checkbox for the same cam.
Repeat for the 2nd cam.
Don’t forget to go through your cams’ Detection Settings, Event Recording and Notification settings and select your new preferences.
Perfect!!
Thank you, my friend!
Henry.
