Adding a camera - piggy-back?
I’m adding a camera right next to one already mounted in my front porch. This one will be pointing in the opposite direction - toward my garage doors. Here’s my question…
The current camera is plugged into an extension cord run from the front porch outlet. Can I simply plug the 2nd camera into the same extension or is there some way to piggy-back the two (not sure I understand how that would happen, but…)?
Thanks in advance. Iris
@Loki answered this before, here’s the link to that thread if you are confused.
No. A standard USB (same one that comes with the camera is fine).
If the cameras are side by side, I’d recommend pickup up a very short USB-A to USB-micro cable. One example:
https://smile.amazon.com/CableCreation-Shielded-Charger-Compatible-Chromecast-x/dp/B013G4EAEI/ref=sr_1_5?ie=UTF8&qid=1548160475&sr=8-5&keywords=short+usb+micro
Thanks for the replies - sorry for the new thread, couldn’t think what this situation might be called.
Still not sure I understand how this works, have to look at one of my current cameras. I didn’t remember the camera having a mini USB port.
The back of the camera has two usb ports, a regular USB and a Micro USB. The Micro USB is what you plugged in to power the camera.
https://support.wyzecam.com/hc/en-us/articles/360019706632-Setup-Mounting
