There are two types of “event recording” that your camera can do, event recording to the cloud, and events recording to local storage. I will touch on both:
- Event recording to the cloud.
To enable events recording to the cloud in a v3, you have to change the toggles in this screen below, which is accessed by going into settings, then “event recording”.
There are two different events that you can record to the cloud, motion events and sound events. These are accessed by going to the event tab off the main home page in the app. This is the same location to enable for the free cloud storage, and the camplus (although camplus have some more settings elsewhere)
- Local storage to the sd card.
To enable local storage, you need a sd card in the camera and then go to the settings menu, then advanced settings, then toggle the switch at the top and choose between the two modes. See below:
There are two modes to local storage to your sd card in camera, there is events only, and continuous recording (which records 24/7). The local storage’s event recording is the one where the full minute is saved where the motion falls, if the motion goes into the next minute, the full next minute is saved to your card. In the local storage events only, it only saves motion events, not sound events. Local storage is accessed by going to the live view of a camera, then to playback at the button of the screen.
Your settings on cloud storage or local storage above, does not effect the other. I’ll also touch on some of your statements to provide some clarity.
To turn on cloud recording, you need to enable the “motion detect” or “sound detect” on the events recording settings page I provided a screen shot above. That settings page, only effects your cloud recording.
There are two seperate modes to locally recording. “Motion” Events only, or continuously, where only one can be chosen at a time. Events only only saves minute chips where the motion event falls to your card, or continuously is always recording to your card.
Cloud storage has its own style of event recording, whereas local storage has its own version of event recording.
Does this provide some further explanation that cloud and local are Independant of each other?
Edit/ if you want more reading on the topic, I’d direct you to the v3 support pages that I’ll link.
https://wyzelabs.zendesk.com/hc/en-us/sections/360011231672-Wyze-Cam-v3
