There’a a 30 second notification lag to my phone. It does activate and catch the motion, it just takes 30 - 60 second for the notification to get to my phone. My Ring gets there in about 2 seconds and my Yi in about 10.
I have hardware decode checked. Is there anything else I can look at here. Also, I’m on Beta, is there a chance that non-beta might have better response time?
If you’re getting 10 seconde delay I’d say you’re okay. based on other cams I used 1o seconds is decent. I just have a hard time dealing with 30 + seconds
