128gb SD Card capped at 30GB
Now, I am wondering how the Sandisk “High Endurance” stacks up to the “Extreme”, and “Extreme Pro”. It is a bit mind blowing looking at all the options, previously not realizing how many there were. The “High Endurance” SD card is the only Sandisk version I could locate that appears to claim to work with dash cams and home monitoring systems. At least that is what it says in the description on Amazon. Here is a link:
https://www.amazon.com/SanDisk-Endurance-microSDXC-Adapter-Monitoring/dp/B07P3D6Y5B/ref=asc_df_B07P3D6Y5B/?tag=hyprod-20&linkCode=df0&hvadid=343224652930&hvpos=&hvnetw=g&hvrand=15229552842871452193&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9028297&hvtargid=aud-802037562948:pla-720630203941&psc=1&tag=&ref=&adgrpid=71764766791&hvpone=&hvptwo=&hvadid=343224652930&hvpos=&hvnetw=g&hvrand=15229552842871452193&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9028297&hvtargid=aud-802037562948:pla-720630203941
From above.
SD / SDHC / SDXC differences - need to know
… and then …
EDIT:
See my post here:
High Endurance line is usually made with higher quality NAND, which means it can take more writes than their other line. The Extreme version usually are made for speed.
In reality, these are all pretty cheap, and all will work, most people just get whatever is available. If you want the better microSD cards, they usually have the higher warranty period associated with them, but, since they are so cheap these days, just get whatever is available, and the lower costs ones will just need to be replaced more often.
You all might be interested in this thread, and this post. :slight_smile:
