Wyze Watch 44, Cam Outdoor & Base Station Firmware Beta Test 9/1
WATCH 44 :
Version: 0.3.97
WHAT’S NEW:
  • Added support for App Management to allow toggling cycle tracking visibility and changing the app order
  • Improved step counting accuracy
  • Improved the raise-to-wake algorithm
WYZE CAM OUTDOOR & BASE STATION BETA:
  • Cam Outdoor: 4.17.1.247
  • Base Station: 4.16.2.24
WHAT’S NEW:
  • Fixed a bug that caused the Base Station to keep flashing blue after changing the connection method.
If your Base Station is stuck with a flashing blue light, please use this temporary fix posted 8/30/21 at 12:30 PM PT to reset it. https://support.wyze.com/…/360015979872-Service-Status
[Mod Edit]: Removed embedded space from version numbers to enhance search clarity.
Just went into the app to see about updating my outdoor cam to the reported versions. However, mine are saying I am at the current version:
Cam Outdoor: 4.17.1.245
Base Station: 4.16.2.18
I will check later, but is there a reason why?
My guess would be that they posted this before it fully rolled out
Any update on this?
Still @ 4.17.1.245 and 4.16.2.18
Same here and it says it is up to date when I check for a Firmware update.
Mine is showing the same, holiday weekend we probably won’t know until Tuesday, but if I learn anything I’ll let everyone know
Just updated mine
Just got the Outdoor cam and Base Station updates. Will test
