Wyze vacuum and black squares on carpet
Vacuum works great on hardwood and tile floors, but when going on our carpet with 4" black border and many 12" squares the vacuum does not know what to do. Tried blocking the cliff sensors and vacuum will not run when these four sensors are block with white paper.
Any suggestion on how to make the vacuum work on this 12x12 carpet?
Just plain white paper didn’t work for me but it works when the paper covered with clear packing tape,
Did you cover just the part facing down to the carpet or also the sides of the sensor? Maybe send a photo of how you covered.
Both sides to make it stiff and shiny, I then cut it to fit the sensor slots. Here’s a youtube link on the subject
