Wyze Universal Wi-Fi Chime additional triggers other than Cameras
The Wyze Universal Wi-Fi Chime (that came with the Wyze Doorbell Duo) can trigger from that Doorbell & from events on any Wyze Cameras.
Request that Wyze allow the Wyze Universal Wi-Fi Chime to receive triggers from:
Motion Sensors
Entry Sensors
Leak Sensors
Wyze Lock
Garage Door Controller
Allow for those triggers to use the many different available chimes.
Please vote for your Wish as one is not added automatically
Note: If you set up an automation, you can set the Chime as a Trigger and have it ring. That should work with the other sensors.
Good Morning @spamomi,
I did see that I could create an automation and use the “Universal Wi-Fi Chime” in this way, but, it appears that it limits you to just 'Ring", which was not ideal.
I want to be able to select what the available Tunes (Modern Tunes, Classic Doorbell Sounds, Animal, Door Sound, Christmas Sound")
I want something ‘subtle’ for when I leave my refrigerator door open in the garage, rather than something that potentially alarms so loud that I jump out of my chair. I currently have a entry sensor flash multiple lights in the house when that sensor is open for greater than one minute, I want an subtle audible notification as well.
I haven’t tested it yet, but I assume “Ring” will use a generic Door Bell Ring? (I’ll test when I have a chance)
Pulled an unused Entry Sensor out of the box, set it up, created an automation to ring the Wyze Universal Wi-Fi Chime, and as I assumed, it produces the default ‘ding-dong’ doorbell when triggered.
So, until Wyze makes the ‘library’ of sounds available for automation from non-camera devices, I will use this ‘ding-dong’ sound for now to give me a quick audible of events such as the refrigerator door being left open (because I have assigned a sound other than this to the door bell)
Exactly. We need the same.
only 2 votes. :crossed_fingers: hmm
