I’d like my Wyze thermostat to be voice controlled by my Google Assistant.
Welcome to the Wyze community @charfran!
The Wyze thermostat is already compatible with Google Home. Here’s some instructions to link your Wyze account with Google Home:
My Wyze thermostat is working with Google Home but Google Assistant does not allow me to give the thermostat voice commands.
Is there a workaround for that?
You may have to clarify your question. Both Google Home & Google Assistant can change the settings on your Thermostat. Even with voice… e.g. “ok google, set thermostat to 72 degrees”.
I tell mine what to do all the time. I can even ask it what it’s currently set to.
It has started working again. I have no idea why it stopped and then restarted. Grrr!
