Hello dear people! I have been quite happy with the thermostat settings and the scheduling. Now, I wanted to change the thermostat settings from Away to Home using Google Assistant. The use case here is that I would like to call Google Assistant on my from work, tell something like “I’m coming home” and it will change the temp setpoints from Away to Home. However, Google Home automations allow only changing the setpoint and when it does, it changes the range +/- 7 degrees F (e.g. when setpoint is changed to 75, range is 68 and 82).
So my questions is if anyone was able to find a work around for this (maybe through IFTTT or else) or knows that there are plans to include this type of integration in the future.
Thanks everyone for your thoughts in advance!
