Wyze thermostat missing c wire connection
Trying to install my Wyze thermostat, I have a c wire from my old unit, but the new Wyze thermostat doesn’t have a c wire connection. I can’t figure out if I’m doing it wrong or if the thermostat is wrong.
Hello @lytlee1 and welcome to the community
The bottom block is mislabeled, as you can see it matches the top. You have 2 options, contact support and they will get you a new one or you can use the following as the wiring order
Top Row Rc - Y1 - Y2 - O/B - G (correct on yours)
Bottom Row - Rh - W1 - W2 - * - C (incorrect on yours)
