I’m trying to install my wyze thermostat. Following the instructions it says I need to use the c wire adapter.
Going to the control panel at my unit and it says I need to label the R,W,Y and G wires. The R and Y wires are easy to label. The W wire has me confused as how to wire it correctly from the adapter to the control board.
And then there is the G wire. It’s not labeled on the control board and I have no idea on what wire to try and connect for the G wire in it’s place.
Please share a wider angle picture. Also your thermostat wiring, and the brand/model number of the air handler.
I see wires labeled C-RV and O-RV, this leads me to think this may be an outdoor heat pump. Is there a blower fan in this box?
Edit: looked up the numbers on this board, it’s a defrost board for a Goodman heat pump. This is not the board that the thermostat connects to.
