Wyze thermostat for Garage heater
I am looking to hook up a wyze thermostat to a new MR heater Max 50,000 btu heater. Anyone have success here? what wires? etc… would be very helpful. This will not have an AC, heat only.
The manual for the heater unit has a page that covers it pretty well.
connect R on the heater to Rc on the wyze,
G to G (optional)
W to W
and
C to C
With the G wire hooked up, you would be able to control the fan separately, for instance if you wanted the fan to run without heat in the summer to provide a breeze.
G isn’t required for operation of the heat though.
