I am trying to get some confirmation, because I believe my thermostats are working, but when setting them up they did not pass the test. The fan never kicked on during the test but they seem to be functioning normally. I have two thermostats on the same system, one is upstairs and one is downstairs. I have a heat pump system for heat. Here is a picture of how they were wired, which is a little confusing because the app doesn’t cover how mine are labeled. My thermostat are honeywell and should be pretty popular.
I’m going from the same Honeywell wiring to the Wyze. I wired the Wyze the same way you did and the app is able to complete the testing but my heat never turns on. It just blows out the same air that it sucks in. I’ve had to go back to the Honeywell to get the heat to turn on. I have the Honeywell RTH958WF1005. I’m in Florida and the HVAC was replaced earlier this year.
That was my problem, I thought, the test it never gets hot but if I turn the heat on it works fine. The testing wasn’t working correctly but it seems to work fine.
so as iv had a similar testing experience I restarted the test and read the instructions very closely… and it does state that it may take a few mins to notice the heat… it took about 4mins till I had heat blowing… it is very important to wait till you feel heat within 5min as one of the key features of the wyze thermostat is to learn how long it take for the system to trigger heat… As the wyze thermostat learns more it then allows the system to Heat before triggering the Blower thus allowing a more accurate reading to help with savings or benefits with running a energy saving system… hope this helps… plz keep myself posted on the progress…
I have this same issue. System tests won’t work at all, but if I manually adjust the thermostat for heat or cool it works as expected. Is this a bad thermostat? Should I request a replacement or be worried?
System tests are only testing out a single component, if you have a multistage system they will not send out the same signals that the thermostat will send out during normal operation, apparently.
I don’t have a multistage system. The issue is in the app. After a couple of hours and resets, we triggered system testing from the thermostat itself and it worked.
