Thermostat Controller Upgrade: Chronotherm IV to Wyze
We currently have a Braemar TA20n Gas Ducted Heater and a Honeywell T8602D Chronotherm IV thermostat controller. We want to upgrade to a Wyze smart thermostat and understand we need a C wire connection to provide power. I have read the Wyze thermostat simplified block diagrams guidance and other C-wire posts which were very helpful, however still have a query specific to our installation that I was hoping could get some advice!
Our current 2-core wiring only has the R and W wires connected as shown in Figure 1 and 2.
While the ducted heating control board indicates it does have a C terminal, the wiring diagram shown in Figure 3 only indicates the W and R terminals.
We have an Olex 3 Core 0.75mm electrical cable with stranding 24/0.20mm wires, shown in Figure 4, that we were planning on replacing the current 2 core cable.
Before proceeding, was hoping to see if anyone had answers to the following queries…
- Without a multi-meter, is there a way to tell whether the heating control board C terminal is powered before I change the current 2 core cable for the 3 core cable?
- Is the 3 Core 0.75mm stranded wire electrical cable appropriate for the Wyze smart thermostat? I saw some smart thermostats indicated they weren’t compatible with stranded wire cables?
Thanks in advance for any help!
