Wyze Solar Cam Pan Firmware Beta Test 4/6/2026
Version: 2.0.0.2130
What’s New:
  • Improved AI smart detection accuracy
My camera has been discharging very quickly since I upgraded to this new firmware. Wouldn’t recommend upgrading.
Is the discharged cause more objects detected and can you change the settings for types of objects to be followed if so?
This FW has done something to the charging on solar. It no longer functions. It has something to do with the recall. We are not being told the full reason for the recall or what is going on. Wyze, pull your head out and speak up. Nothing your are doing currently makes any sense in regards to this recall and how you are handling it. This FW has essentially disabled the reason for having the cam in the first place, the Solar charging in a location without AC. You can’t downgrade FW from what I can see, so I’m just stuck liket his now. Unusable camera with only an option to refund and return is… Because people don’t understand how screws work? come on Wyze, WTH is going on?
