Wyze Solar Cam Pan Firmware Beta Test 1/5/2026
Version: 2.0.0.2017
What’s New:
  • Improved event recording cooldown behavior and separated it from Motion Warning and motion-activated spotlight settings.
  • Enhanced live stream connection stability
  • Enhanced overall system stability and reliability
  • Optimized power management logic in charging mode to reduce frequent Wi-Fi disconnections under low-power conditions
  • Fixed an issue where the battery level could display sudden jumps while charging at low battery levels
  • Fixed an issue where the infrared (IR) light could remain on after exiting Night Vision mode
  • Fixed an occasional issue where the siren light could stop flashing after the first few seconds
I believe I’ve actually observed this behavior but didn’t give it a lot of thought at the time. It’s good to see that this has been recognized and is being addressed. :+1:
