Can I use the Wyze Sense to activate the new wyze outlet?
Can I control the duration of the trigger? Example: if the Wyze sense is triggered, activate the outlet for 1-min, 2-min, 30 min and then shut off if not still sensing motion?
This would be great if it can be programmed like that.
I’m pretty sure that can be done in the shortcuts. I have my bulbs set to turn off in an x amount of time with the sensors, my understanding is the Wyze plug will work the same way.
Edit: Like Jason mentioned you will need two separate shortcuts to make it work.
