I’ve tried looking it up in the knowledgebase, but it wasn’t helpful.
After I flip the vacuum upside down and push two blue tabs towards each other to remove the retaining plate, how do I then remove the main brush? There’s so much hair/gunk on it I can’t see anything below/around it to figure it out.
Also, Wyze, would you please consider the main brush with the solid silicone instead of bristles? Something like this from my old Neato:
With your vacuum upside down, pull the left end of the brush (the end closest to the rotary edge brush) straight up, then to the left. After cutting the stuff off the brush, reinsert right end into the hole and drop the left end into the slot. Reattach plate.
Edit: When reinstalling the brush, if you forgot which end went where… one end free-spins and one end is fixed. The fixed end goes into the right side first, then the free-spinning end drops into the left near the edge brush.
What if I’m pulling on the roller but it seems to be stuck in the vacuum? I’ve had mine for years and it always comes out easily, but this time it seems to be stuck in there. I’ve even tried using pliers to pull it out but it’s hard getting a pivot point on anything since everything around it is plastic.
Assuming you flip your vacuum, have the two blue tabs on top of/above the brush when you removed the plate, pull on the left hand side of the brush. The right side gets inserted into a hole/recess. If you pull on the right side, you will break something. Left side can get stuck with enough hair/stuff clogging it.
