Wyze Plug Outdoor HomeKit Support
It’s likely been asked before, but, any chance that HomeKit support may eventually reach this device? Currently using a $50 outdoor plug alternative with HomeKit support. Same question for the V3 & Outdoor Cam.
Secondary question. The v3 is significantly superior to the Outdoor in specs, would that be correct?
Welcome back @bhall2236!
HomeKit support for all Wyze products is on the #wishlist. Wyze is currently “researching” this.
More information here:
Thanks for the response! Would you happen to know if the WCO and v3’s do have the hardware to support HomeKit if it is indeed implemented at some point?
How much better does the v3 perform over the WCO?
Has anybody had success with a solar panel system to keep the v3 powered outdoors?
