Wyze Plug not responding to time change
Interesting: my last post was about the fact my two Wyze plugs continued to operate just fine after a power outage - without any effort on my part. Now, however, one of them just decided to ignore the fact we changed from Daylight Savings to Standard the beginning of the month. The schedule - which is still showing in the details for the plug, is to turn on at 7a and turn off at 9p. Now, the plug turns on at 6a and turns off at 8p. Since the schedule for the plug shows the correct times, I can’t figure out how to get the plug to change to the correct setting. Anyone else having this problem? Anyone have an answer?
Appreciate the help.
Have you tried power cycling the plug…
Confirm that this is via a “timer” in the plug as opposed to an Automation (formerly called Rule)?
I only have two plugs and only one of them has an Automation, and that did run correctly last night.
