Will try and make this short. I recently set up 2 wyze cams in my home that use the RTSP demo firmware to send video streams to my Synology disk station. I’d like to help a friend who is roughly 1000 feet from my home. I want to set up one of the new outdoor cams on his WIFI and have the feed sent to my disk station. Is this possible?
In simpler terms. I want what the cam sees to be sent to my location. TIA
Are you talking about the WCO? Or another Wyze cam version that is outside? The WCO or the v3 doesn’t have the RTSP firmware available currently. Only the v2 and pan have it currently.
Bummer, Was looking for a wireless outdoor on battery with RTSP. Thank you!
I am not aware of any battery powered camera that has RTSP. Do you know of ANY? I doubt the WCO ever will otherwise you’d have to charge it every 6-8 hours.
Is there an outdoor wired cam that does have RTSP
The only Wyze cams that have RTSP now is the V2 and the PanCam. Although officially neither of these are outdoor cameras, folks have had varied success with these being outdoors, especially when covered from the elements.
Have your neighbor set up the cam as if his.
Then have him share it with you through the WYZE app
