Wyze OG & OG Telephoto Firmware Beta Test 2/8/2023
Wyze OG:
Version: 1.0.58
What’s new:
  • Fixed a possible crash for free users
  • Fixed a crash that occurred when recorded video was downloaded with Record Sound turned off
  • Fixed a dead loop caused by a time error when using microSD card Playback
Wyze OG Telephoto:
Version: 1.0.58
What’s new:
Updated both without issue.
Note: The Firmware Update menu option, in Account, only showed the OG-S FW and not the OG-T. I had to start OG-T Live Stream then go to the Device Info and Update from there
Same experience. OG-T is not available thru the Bulk Updates in the Android Production App, Got a FW Update Available pop-up when opening the OG-T cam to Live Stream and an update available thru the Device Info.
Both updated successfully.
Did this firmware get pulled? I don’t see it in either bulk update or when I go to individual cameras.
Do you have each OG selected in the Beta Program settings under the Account tab?
D’oh!!! Well, I do now! :wink: Thanks!!! :smiley:
