Wyze Mesh Router & Mesh Router Pro Firmware Beta Test 4/20/2023
Wyze Mesh Router Beta:
Version: 1.0.1.108
What’s New:
  • Added support for NAT loopback
  • Updated local UI SSL certificate
  • Fixed a bug that prevented the root router from obtaining IP from an ISP modem if the router boots up before the modem
  • Fixed a bug that prevented IPv6 from working properly
  • Fixed a bug that prevented parental controls from taking effect when an uppercase character was configured in the domain
  • Fixed a bug that prevented client devices from obtaining IP when connected to a guest SSID for a satellite router with Ethernet backhaul
Wyze Mesh Router Pro:
Version: 1.0.1.109
What’s New:
Installing on my Mesh Pro’s
Will report back on how it goes.
Started at 5:43pm. :slight_smile:
EDIT
Ok, Completed the install and was connected to main router at about 5:47 (rounding up).
At 5:53, everything stabilized and all devices connected.
I have the Main Root Router and a Satellite Node.
So far all is working great,
Will do formal testing now.
Updated root & 2 wifi nodes to Beta. No issues during update. All devices returned online after network reboot. Monitoring.
Just finished the update for the Pro router, went smoothly! Will continue to monitor and test!
Router Pro updated yesterday smoothly to the Beta Version: 1.0.1.109. No issues during router setup. Adding more devices to the router and will continue testing for any bugs or issues.
IMG_1986
I am testing the released FW for these devices and have not run into any real issues. Performance is great.
However, today I noticed the following:
I setup an original Wyze Doorbell, not the Pro, this morning and I don’t see it listed as a connected device. The Doorbell is working, as I am testing VoIP, but I cannot seem to locate it in the list. Confused, I searched for the Doorbell Pro, I don’t see that in the list either.
I created a log from the Wyze Mesh Router Pro: 1015815
It would be nice if we could get a report or view, even if it is Web Only, to display all devices connected to include: Name, IP, Mac, Node connected to, Node Connection Type
@spamoni
If you reboot the doorbell does it then show up?
No, I also just added the Original Doorbell as I am testing the VoIP.
I was able to find my doorbell.
Mine is showing listed under the latest firmware…
I wonder what’s different between ours
