Wyze Light Bulb and Headaches
Is anybody else getting headaches from the Wyze light bulbs? I put one of these in my bathroom so I can dim it most of the time. I rarely used it at 100%. I can’t notice a flicker unless I’m showering and then I can clearly see a strobing effect on the water.
Background: I spent weeks with daily headaches and thought I had something seriously wrong. The headaches went away when I finally went camping for a week. I realized it had to be an environmental issue at home. I looked around for all possible changes and eventually removed the Wyze bulbs as a trial. To my surprise the daily headaches stopped.
Testing: I build a quick test fixture with a photo transistor, resistors, an alkaline battery, and an oscilloscope. I made some discovery type measurements that are not meant to be scientific level. I found that the Wyze bulbs have a PWM frequency of 1kHz. That should be high enough not to be noticeable. But, the light emission generates a waveform that is abrupt. In contrast, dimmed Feit and Cree LED bulbs have a 120Hz frequency but the light to dark change is gradual. In the two attached pictures you can see two bulbs dimmed to 50%; a Wyze (via app) and a Cree (via wall dimmer). The Wyze has a maximum voltage (off my photo transistor) of 1.275 volts and minimum voltage of .047 volts. It varies from 100% to 4%, 1000 times per second. The Cree has a voltage of 1.25 volts and .53 volts. It varies from 100% to 42%, 120 times per second.
Wyze Bulb at 50%
Cree bulb at 50%
Conclusion: I’m figuring the large and abrupt change of the Wyze bulb is what may have been causing my headaches. Just wondering if others had similar experiences.
I’m having the same issues. After going away for a week, when I came back, I was experiencing the same issue.
