Wyze in the Philippines
If I bring a Wyze cam to the Philippines - will it work there?
There are reports of them being used successfully overseas, so there’s a good chance it will work. However, the cameras are not supported outside of the United States.
Were you able to get this working in Manila ?
Has this been resolved or is there still security issues? I’m hoping to upgrade my cameras and give my old set to my parents in the PI.
Hello, I just moved back to manila this year and have successfully installed a couple of V2 and V3 with spotlight. All have been working properly on 220V power supply using the provided power bricks.
However, you might not be able to use the Wyze bulb or the Smart plugs that use 110V.
Hello, what power brick did you use? Planning to send V3 to my parents and I want to find a dual volt converter too.
The power adapter that comes in the box with the V3 camera states : Input 100/240 volts, 50/60 HZ and the output to the camera is 5 Volts 1 Amp.
The provided power adapter must be plugged into an outlet indoors or a weather proof outdoor outlet with weather proof cover so you don’t burn the house down. The camera can be used outdoors, just not the power adapter.
You can send the same power brick that came with the Wyze. Mine has been working well for the past year. There is no need for a converter or a transformer
As other people have said, the brick itself is not waterproof so make sure they have it covered if they are planning on placing it outdoors. (if those ever break, the newer powerbricks sold in stores here should be enough to power them) hope this helps
Hello Brother, Sounds like you are already very familiar 'bout using the Wyze cam in the Philippines with no issues. I was planning to bring some V3’S soon and I was wondering if I can use my Wyze account here in the US to activate them or Do I have to create another account for the Philippines ? Please let me know, I would really appreciate it. Thank you.
I had similar question, did you ever find the answer to this, appreciate it if you can share it. Thanks
I bought the wyze from Amazon and shipped directly to the Philippines. We didn’t have to use any voltage converter. We also used the same wyze account that I’ve setup here in the US. Hope this helps.
The stock Wyze power adapters are rated for 100V ~ 240V A/C, 50/60Hz.
